Motorproblems 350 V6 petrol engine 272
Old 12-16-2010, 01:41 PM
MBNorway's Avatar
Default Motorproblems 350 V6 petrol engine 272
Due to weak materials in balance shaft for engine numbers up to Serial No. 2729..30 468993 , Mercedes Benz has issued the enclosed service bulletin S-B 03.30/08 j as of june 17 2009. Based on this the balance shaft will have to be replaced. If you haven't heard of this before, please notice this and do an enginge diagnosis for this asap. Symptom is yellow check engine light coming and going. Anyone out there who has experience on this please give me a pm, also describing how your local dealer handles this, as this should be a warranty issue.
Best from Kjetil Halvorsen Norway
Old 03-20-2011, 10:41 PM
thangng's Avatar
Default 2008 E350: balance shaft problem
I just got my CPO 08 E350 with 33K mile in Feb/2011, within a week the CEL turned on then went away the next day, It happened a couple more times just like that but the car/engine ran smoothly . I took the car to the dealer for check. They diagnosed with code P1200 and P1208 and replaced the magnets on the left bank intake/exhaust cams, and declared problem fixed, I took the car home and the very next day the CEL turned on again for two day and turned off by itself again. I took the car back to the dealer and later they informed me that the procket and balance shaft needed to be replaced.
It's been two weeks and the dealer has not finished the repair yet.
My engine serial# is 2729..30 78xxxx which is > 2729..30 468993, is It possible that my engine has the same problem as described in S-B-03.30/08i?
Thanks,
mystery156
01-04-2014 04:32 AM
johndragon77
05-22-2013 12:01 PM
greatkid1985
11-11-2011 06:57 AM
Amatoren
07-18-2011 03:10 AM
fj20det
05-20-2009 02:31 AM
Quick Reply: Motorproblems 350 V6 petrol engine 272
