ML430 changed battery now gauge cluster wont work
Hello, I cannot give you a specific answer, but might point you on some trouble spots that are general to most automobiles. I assume that you have checked your fuses. #1 question, do your headlights work ? If yes I suspect that you may be experiencing the first symptoms of a failing ignition key switch. God luck Allan
bright rider
09-12-2008 02:03 PM
ddtbreakfast
04-21-2008 11:34 PM
