ML 430 will not shift out of 1st gear
Old 01-27-2008, 05:55 PM
mercedesml430's Avatar
Default ML 430 will not shift out of 1st gear
Recently my kid spilledpepsi around and into the area where gear lever is located and now car will not change gears at all, also it will not engage reverse unless I turn off the car turn the key once (just turn it once not crank it) put it into the park turn it back on then move it into the reverse gear. Dashboardwas displaying"Start Error" message but that went away. Also dashboard display will not show which gear car is in just grayed out.
Any help is appreciated.
Old 01-27-2008, 07:08 PM
chassis221's Avatar
Default RE: ML 430 will not shift out of 1st gear
the correct fix is to replace the whole shifter unit. ive heard you can remove the assembly and clean them but ive never done that myself.
mbenz80
09-17-2009 10:18 PM
Johnny Thundereagle
05-28-2009 10:53 AM
mercedesml430
03-18-2008 02:22 PM
redrockmountain1000
08-22-2007 12:46 PM
jazharp
08-19-2006 03:06 AM
Quick Reply: ML 430 will not shift out of 1st gear
