Error Codes for 1999 CLK430
Old 07-01-2004, 08:38 PM
Sarge's Avatar
Default Error Codes for 1999 CLK430
Guys,
My #$%@! "Check engine light" is going on and off intermittently. I had a friend of mine perform diagnostics, and he found two codes. Both of them point to the "Fuel Trim 1 and 2". My transmission is running smoothly. Is this most likely the AMM?
Any advice (besides bring it to your dealer), would be appreciated.
Thanks!
Old 07-01-2004, 10:34 PM
Default RE: Error Codes for 1999 CLK430
p0170 you hae to change the air flow sensor that the one between air filter and thorttle plate inner.on the air duct.
this sensor assembly with 4 sensor ,better buy the new type from the dealer aoid the old type....from 1994 till 2001 all have the same problem.
i have been changing around 25 cars already......very bad design.......[:'(]
Old 08-03-2004, 05:13 PM
Sarge's Avatar
A new AMM fixed the problem! $249 for the part, and $20 labor. Sweet!
CRyanGo
09-25-2013 11:49 AM
vignesh
09-03-2012 07:00 PM
tjdog20
10-14-2011 06:09 PM
SeiyaMiami
03-16-2009 11:13 PM
steveland
01-10-2005 12:36 AM
Quick Reply: Error Codes for 1999 CLK430
