BAS/ESP warning light on SLK
The BAS/ESP warning light on my SLK stays on. The brake lights and brake control of gear selection work, so presumably the brake switch is working. I have tried left to right lock and repeated this but the light still stays on. ABS warning light switches off as normal. Any suggestions?
RE: BAS/ESP warning light on SLK
Hi Ian,
I'm interested in this one although I don't really have any way forward. I waited to see if anybody else replied.
ABS and BAS are two systems that to some extent overlap so I am baffled why one is OK and the other not.
I still suspect that it has something to do with the BAS sensing system which determines WHEN you need emergency braking pressure. Not sure exactly how this is achieved.
My suggestion is to get the diagnostics scanned. This will give a code which will point you (us) in the correct direction.
Stuart
Stuart
hi,i work in garage ,we have a s32o cdi ,2005,abs light,esp,bas,and brale lights stays on,after scanning we changed a brake light swich ,the brake lights,and abs still stays on and on the sccaner shows faulty brake light swich ,and it dosnt clear it ,any body come a cross with same problem?
#10
esp bas abs lights
I had this happen to me and thought it was my brake light switch. I ended up having a couple of incorrect tail light bulbs which was causing a bulb malfunction light to come on. I had just bought the car. I unplugged the brake light switch and plugged it back up. This cleared the abs, bas, and esp lights out. If there had been a real problem with these systems, they would have more than likely come back on the within seconds.
