any common problems with evap leaks?? - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 03-08-2005, 02:25 AM
Default any common problems with evap leaks??
I have a c230 kompressor that blinks at me constantly. I got the codes and got a p1457 large evap leak code. tried to perform a smoke test and I don't know how to shut the cvs solenoid...any help??? maybe the cvs is the problem but I know it isn't the cap already tried that! It has always been hard to fill at the gas station if that is related possible orvr?? that shouldn't cause a leak though??
Old 03-08-2005, 06:27 AM
sleepwalker's Avatar
Default RE: any common problems with evap leaks??
what is cvs and orvr?
Old 03-08-2005, 10:46 AM
cvs=canister shut valve
orvr=rollover valve
Sorry I have been a Honda tech for twelve years, those are Honda's name for the valve/solenoids. I have a scanner to use on honda's but it won't work on my car though, not for operating switches anyway.
Old 03-09-2005, 12:17 AM
i get it... purging valve.
if the vent line is clogged, it's very difficult to fill the tank with fuel.
check the charcoal canister first.
[IMG]local://upfiles/1/7420EEC3420A4AA3A0A5BDC04499BD68.jpg[/IMG]
Old 03-09-2005, 03:05 AM
Is that diagram for a c230 kompressor? My diagram is different. My purge valve is on the dr/front strut tower and my canister is above the dr/rear tire with a vent valve located after it??
I will remove the canister and see if it is broken up or loaded with fuel. I s the canister a common problem?
Old 03-09-2005, 04:30 AM
yes it is.
[IMG]local://upfiles/1/DDA2A42042F141DEB8F34F6FD34EBC3E.jpg[/IMG]
Old 03-10-2005, 11:10 PM
thank you for the images, they put me in the right direction. Those are for a w203 body, I have a w202 body that was the difference in the diagrams that I had. The parts are all the same though, again thank you for thr help.
Thread Thread Starter Forum Replies Last Post
wanted: ponton wagon (any model, any condition, any year, etc...) xjvoorheesx Private 'Wanted' Classifieds 0 07-29-2006 02:21 PM
anyone repaired any evap leaks on a c230?? snowisgr8 Mercedes C Class 0 03-08-2005 02:30 AM
Any common problems on 2001 or 2002 SLK's? 1BADSLK Mercedes SLK Class 0 12-14-2004 11:49 PM
Any common problems on 2002 SLK AMG? 1BADSLK Mercedes AMG Class 0 12-14-2004 11:46 PM
most common problems with C230s youngmercedes Mercedes C Class 0 08-11-2004 12:05 AM
Tags
03, 2000, 2005, c230, canister, evap, kompressor, leak, mercedes, purge, small, solenoid, valve, vent, w202
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
