420 sel starting and stalling problems - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 08-19-2007, 07:25 PM
Default 420 sel starting and stalling problems
I have a 89 420 sel that has recently begun to give me problems starting. I get in the car and it starts right up and runs great, I get to work 5 min from my house and when I come out of the office to go home it won't start. Turns over great but won't start. Yesterday I finally drove it a longer distance and it stalled while driving, it started a couple more times and let me go about 300 ft each time, but eventually quit and had to be towed. Any ideas?
Old 08-20-2007, 12:14 AM
Default RE: 420 sel starting and stalling problems
I am gonna say it may be a fuel pump relay. Extremely common during summertime. It should be located on the firewall next to engine control unit and klima relay. Other than that, i'd say possibly a "green lead" which is essentially the same as a crank position sensor but mounted inside the distributor and runs to the ignition control unit. Also, dist cap and rotors have trouble with the heat if the contacts are faulty. With this vehicle, there are many variables which can cause so many problems but I would start with the fp relay first. You can take the fp relay casing off and inspect for a solder joint which breaks and depending on temperature makes contact. Eay to do if you know what u r looking for but probably difficult if u don't
Thread Thread Starter Forum Replies Last Post
1990 560 SEL Stalling problems dharper1000 Mercedes S Class 0 03-04-2012 04:27 PM
420 SE (SEL) and/or 380 SE (SEL) Belt Diagram northbeachfilms General Tech 0 07-28-2009 03:24 PM
1987 420 sel brake problems Roberts mercedes General Tech 0 01-24-2007 02:32 AM
420 SEL vs. 560 SEL bsutton101 Mercedes S Class 4 10-06-2004 06:47 PM
86 420 SEL -- problems? johnmik Mercedes S Class 2 03-19-2004 01:41 AM
Tags
1991, 420, 420sel, 89, benz, common, faulty, forums, fuel, issues, mercedes, problems, pump, sel, stalling, symptoms
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
