1988 300SE Transmission Problem - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 01-15-2005, 12:39 PM
Default 1988 300SE Transmission Problem
Great Site! Glad I found it. My 1988 300SE, with 154,000 miles, will not shift into overdrive. Shifting from 1-2, 2-3 is fine. Overdrive will not engage, which results in POOR mileage. Any advice?
Old 01-15-2005, 01:02 PM
sleepwalker's Avatar
Default RE: 1988 300SE Transmission Problem
that's because you got no overdrive.
you have S and W switch?
on S, it will start from 1st gear.
on W, it will start from 2nd gear... that's why your count is missing 1 shift.
Old 01-15-2005, 01:12 PM
Thanks for the quick response. However, I'm not following the "S" and "W". My shifter shows:
D
Maybe I'm confused on that. It was my assumption that the car has a fourth gear.
Thanks.
Old 01-15-2005, 10:20 PM
Beau, I have an 89 300 SE and when I first got it I thought the same thing. Mine does not have a S and a W switch. It will always start out in 2nd unless I really floor the accelerator. I still get decent milage in spite of that. Be sure you use only High octane fuel or you will really have other problems.
Old 01-15-2005, 10:26 PM
Per a response from another forum:
The SE starts in second gear. First gear is activated by the "kick down switch" located behind the accelerator pedal.
Old 02-02-2005, 03:17 PM
the 4rth gear also kicks in at a very low rpm its like 3000 on my 300se it is there its just suttle
Thread Thread Starter Forum Replies Last Post
1988 300SE, chrome ReubsLTD General Tech 0 07-08-2010 08:59 PM
1988 mercedes 300se wont start jay690045 General Tech 0 02-13-2008 04:53 PM
oil leak on 1988 300se zipper12 General Tech 3 12-16-2007 07:46 PM
1988 300SE Will Not Start gasparetto Other 2 03-21-2007 07:22 PM
1988 Mercedes 300SE mermar For Sale / Trade Classifieds 3 03-13-2006 02:20 AM
Tags
1988, 300, 300se, 89, benz, drops, forum, gear, mercedes, overdrive, reviews, se, series, top, transmission, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
