190e 2.6 vacuum hose - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 11-12-2007, 05:33 AM
Default 190e 2.6 vacuum hose
Would one of you guys in here with a 190e 2.6look underyour hood and tell me where a vacuum hose goes?
On the exhaust side of the engine, actually under the exhaust header, I have avacuum actuator with NO hose connected.
But where does the other end of the hose go?
pic attached.
Thanks Blue
[IMG]local://upfiles/10968/FE7219397ED048FDA735F893D1DE7420.jpg[/IMG]
Old 11-13-2007, 01:20 AM
Default RE: 190e 2.6 vacuum hose
Do you have a vaccume leak right now?
Looks like it's an air injection actuator. It should have a manifold source. What I don't know is if it's t'd in with anything else.
Alot of people disconnect those and plug off their vac feed when they go bad. Was it hooked up before-hand? Or was it just something you noticed.
Old 11-13-2007, 01:55 PM
I loaned the car to a friend. He kept it so long, he made me an offer on it and bought it. He lived in a non-emmision country and had someone disconnect a few things. Now that I have it back, I need to get it hooked back up. The car is running WAY too rich, It is running rich enough that the fuel air adjustment is out of range. I'm thinking its not getting air from the air pump.
I have vacuum ports available, which are now capped.
Old 11-14-2007, 10:42 AM
Will that device work if I conect the vac line to any intake port?
Or does it go to one of those solenoids near the shock tower and battery? I'm hoping that someone that has a 2.6 can just look under their hood.
Old 11-15-2007, 10:56 AM
Can I PAY someone to look at their vacuum hose for me? Blue
Old 11-15-2007, 07:15 PM
In spirit of what may be a useless reply; I will tell you that my 1989 190E 2.6 does not have that hose assembly. Sorry.
Old 11-16-2007, 01:20 PM
Thanks, for looking,
Old 11-19-2007, 04:29 PM
I would like to thank my neighbor David for letting me look under the hood of his 190. Got it!
Thread Thread Starter Forum Replies Last Post
brake booster vacuum hose augF185 Mercedes C Class 0 11-21-2008 01:07 PM
'04 C230: Oil in Engine Harness, Blown Vent Hose, and Vacuum Pump Leak misslivvy Mercedes C Class 6 09-12-2008 11:05 AM
vacuum hose benzman83 Diesel Discussions 2 07-18-2008 01:40 AM
190E 2.6 vacuum hose location BlueSilver Other 0 11-11-2007 04:46 PM
need need vacuum hose diagram 83-300td chaz13 General Tech 0 05-10-2004 12:57 PM
Tags
190, 190e, 1989, 26, bad, benz, disconnect, hood, hose, leak, line, lines, location, mercedes, vaccum, vacum, vacuum
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
