Diesel Performance A discussion section for performance diesel modifications.
W123 na manifold on 82 300sd (faster bottom acceleration/ adding IC)
Old 10-11-2012, 06:00 AM
The Dude's Avatar
why so low? i somehow got the idea that it could pull off 15psi easily. what happens if it is installed with no wastegate?
  #22
Old 10-11-2012, 06:41 AM
The Dude's Avatar
side by side the hx30 & garette t3 are similar in size. Its much smaller than the hx35 i previously had. so your saying that theoretically its still too big to spool up to full potential on the om617 & its almost impossible to do the engine massive damage by not having a waste gate?
btw my old t3 that barely hit 9psi with wastegate fully tightened - i took the cover off of the back of the wastegate and the metal flange/seal was cracked & twisted inside- simple fix?
apmattg
08-22-2013 04:18 PM
hamo1264
03-30-2009 05:57 AM
Billbeme
07-01-2008 06:38 PM
ydlee
10-01-2007 12:11 AM
slow
01-31-2007 12:08 PM
Quick Reply: W123 na manifold on 82 300sd (faster bottom acceleration/ adding IC)
