Turbocharger information, VNT and wastegated - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 05-09-2011, 09:56 AM
ForcedInduction's Avatar
Default Turbocharger information, VNT and wastegated
Variable Geometry Turbine turbos aka VNT, VGT, VVT, AVANT and VTT.
For wastegated turbo information see post #2.
This will be updated as new information is gathered.
Turbos are listed in order of frame size.
Last update: 05/09/2011 Added Holset HE341VeTi
MHI TFO35HL6b-13TB/VG BMW 320D 177hp
Compressor
Inducer: 38.3mm
Exducer: 51mm
Turbine
Inducer: 43.2mm
Exducer: 37.8mm
GTB1756VK Audi 2.7L TDI 190HP
Compressor
Inducer: 41.5mm
Exducer: 56 mm
AR 45
Turbine
Inducer: 50mm
Exducer: 41mm
GTB2056VK- 2007+ Dodge/Freightliner/Mercedes Sprinter 3.0L CDI, 2007+ E320/E350 BlueTec and R/ML/GL320 and 350 CDI/Bluetec
This is a ball bearing turbo
Compressor
Inducer: 41.5mm
Exducer: 56mm
Turbine
Inducer: 48mm
Exducer: 43mm
GTA2056V- Jeep Liberty 2.8L CRD
Compressor
Inducer: 39.55mm
Exducer: 56mm (49 Trim)
.53 A/R
Turbine
Inducer: 47mm
Exducer: 42.7mm
.64 A/R
GTB2056VK Audi Q7 3.0 TDI 233HP
Compressor
Inducer:41.5mm
Exducer:56 mm
AR 45
Turbine
Inducer :50mm
Exducer:43mm
GT2256V- 2001-2006 Dodge/Freightliner/Mercedes Sprinter 2.7L CDI.
NOTE: The compressor housing covers are not interchangeable between the 01-03 and 04-06 series turbos. The 04-06 has a slightly larger (.5mm) compressor inducer.
Compressor
Inducer: 40.3mm
Exducer: 56mm (51.8 Trim)
Housing Inlet: 60mm
Housing Outlet: 35mm
.53 A/R
Turbine
Inducer: 49.4mm (est.)
Exducer: 41.7mm
.64 A/R
(Late 2004-2006 electronic version pictured)
GT2359V
OM613, OM648, AMG OM612DE30
Compressor
Inducer: 44.5mm
Exducer: 59.4mm
12 blades
55 trim
.51 A/R
Turbine
Inducer: 50.5mm
Exducer: 46.5mm
9 blades
GT2260V BMW 330d E90 233HP
GTB2260VK and GTB2260VZK Audi 3.0L TDI 233/240HP, Audi Q7 V12 TDI (2 turbos)
Compressor
Inducer: 44.5mm
Exducer: 60mm
AR 45
Turbine
Inducer: 50mm
Exducer: 45mm
GT2360V
Compressor
Inducer: 42.5mm
Exducer: 60mm
12 blades
50 trim
Turbine
Inducer: 50.5mm
Exducer: 46mm
9 blades
GT2556V
BMW 730D P/N 454191-1
Compressor
Inducer: 40.3mm
Exducer: 56mm
Turbine
Inducer: 51.5mm
Exducer: 47mm
GT2559V
Compressor
Inducer: TBD
Exducer: TBD
Turbine
Inducer: TBD
Exducer: TBD
KKK/Borg Werner BV50 VW 3.0L TDI and Porsche 997
Compressor
Inducer: 44.5mm
Exducer: 50mm
Turbine
Inducer: 43mm
Exducer: 59mm
GT3063KLV
Most likely Hino Truck FD, FE, FF and SG Models
Compressor
Inducer: 43.7mm
Exducer: 63mm (48 Trim)
Turbine
Inducer: 53mm
Exducer: 47.4mm
Garrett GT3571V Misc. Hino applications
Compressor
Inducer: 50mm
Exducer: 71mm
Turbine
Inducer: 60mm
Exducer: 51mm
Holset HE341Ve- 2006 Ford F650 with the 5.9L Cummins ISB
Compressor
Inducer: 53mm
Exducer: 76.5mm
14 blades
48 trim
Turbine
Inducer: 69mm
Exducer: 59.4mm
11 blades
Total weight 39lbs
Garrett GT3782V- 2003-2005 Ford 6.0L PSD
Compressor
Inducer: 58.00mm
Exducer: 81.55mm
.58 A/R
Turbine
Inducer: 72.25mm
Exducer: 66.45mm
.9 A/R
Garrett "Single Sequential Turbocharger"- 2011+ Ford F-Series, 6.7L "Scorpion" Powerstroke
Compressor (inner and outer)
Exducer: TBD
Inducer: TBD
Turbine
Inducer: TBD
Exducer: TBD
Holset HE351Ve- 2007.5+ Dodge 6.7L Cummins
Information on the actuator: http://delphi.com/manufacturers/cv/p.../smart-remote/
Information on Holset VGT operation: http://www.diesel.org/UserFiles/File...Wilman%201.pdf
Compressor
Inducer: 60mm
Exducer: 86mm
14 blades
Turbine
Inducer: 70mm
Exducer: 60mm
12 blades.
Total weight 47lbs
Holset HE431VTi and HE431VeTi- 2006-2011 Cummins ISL and ISM
Compressor
Inducer: 60mm
Exducer: 85mm
Turbine
Inducer: 76mm
Exducer: 67mm
Holset HE451Ve- 2008-2011 Cummins ISM and ISX
Compressor
Inducer: 60mm
Exducer: 90mm
Turbine
Inducer: 80mm
Exducer: 70mm
12 blades
BorgWarner compound turbos- 2008-2011 6.4L Powerstroke
Model: 174080B
LP Compressor
Inducer: 65mm
Exducer: 92mm
LP Turbine
Inducer: 80mm
Exducer: 73.5mm
Model: 174662
HP Compressor
Inducer: 52.5mm
Exducer: 74mm
HP Turbine
Inducer: 71mm
Exducer: 62.5mm
Holset HE551V- 2002-2006 Cummins ISX
Compressor
Inducer: 71.75mm
Exducer: 108.1mm
16 blades
Turbine
Inducer: 86mm
Exducer: 75mm
12 blades
Old 05-09-2011, 10:10 AM
Default Wastegated turbos
Wastegated turbos
Last update: 2014/09/26 Added IHI RHB31 (VZ21)
IHI RHB31 (clone version is called VZ21)
Compressor
Inducer: 24.25mm
Exducer: 37mm
8 blades
Turbine
Inducer: 35mm
Exducer: 26.5mm
9 blades
Garrett/AiResearch T3-45 1978-1985 300D/TD/CD/SD (concurrently used with the K26 from 83+)
Compressor
Inducer: 40.5mm
Exducer: 60mm
12 blades
Turbine
Inducer: 62.5mm
Exducer: 43mm
11 blades
.43 A/R
Garrett/AiResearch T3-50 1986-1987 300D/TD/SDL
Model: TB1359
Compressor
Inducer: TBD
Exducer: TBD
Turbine
Inducer: TBD
Exducer: TBD
Garrett/AiResearch T3-55 1991-1995 S350/350SD/300SDL
Model: TBO390
Compressor
Inducer: TBD
Exducer: TBD
Turbine
Inducer: TBD
Exducer: TBD
KKK K26 1983-1985 300D/TD/CD/SD (concurrently used with the T3-45)
Compressor
Inducer: 39.6mm
Exducer: 65.9mm
36 trim
12 blades
Turbine
Inducer: 64.3mm
Exducer: 45.6mm
12 blades
Total weight 20lbs
Holset HE221W
Cummins ISBe/QSB 3.9/4.5 and ISF 2.8/3.8, Brazilian Ford F-250 (2006-2012)
Billet compressor wheel
5cm, 6cm, 7cm and 8.5cm turbine housing options
Identical to the HX27 except for having a billet aluminum compressor wheel
Compressor
Inducer: 43.5mm
Exducer: 60mm
12 blades
52 trim
Turbine
Inducer: 53mm
Exducer: 45.7mm
11 blades
Holset HE211W
Cummins ISBe/QSB 3.9 and ISF 2.8/3.8
Billet or cast compressor wheel
5cm, 6cm turbine housing options
Compressor
Inducer: 40.6mm
Exducer: 50.6mm
53 Trim
Turbine
Inducer: 46.6mm
Exducer: 41.3mm
Schwitzer/Borg Werner S200
Compressor
Inducer: 44mm
Exducer: 62mm
Turbine
Inducer: 58mm
Exducer: 51mm
Holset HX/HY30- Various Cummins 4BTa and John Deere applications
Compressor
Inducer: 44mm
Exducer: 73mm
6 blades
36 trim
Turbine
Inducer: ?mm
Exducer: ?mm
? blades
Schwitzer S2EGL069 (S2E, 103-2085)
Caterpillar 3116 170,185 HP, Various applications (Bus, Semi, GMC TopKick)
Compressor
Inducer: 57.5mm
Exducer: 76.2mm
57 trim
12 blades
0.60A/R
4" mouth, 2" outlet
Turbine
Inducer: 69.75mm
Exducer: 60.5mm
10 blades
0.70A/R
T3 flange w/split ports, 4" v-band outlet
Schwitzer S410 (0080962999)
2001-2008 Freightliner Turbobrake
MBE OM460LA 435
Compressor
Inducer: 66mm
Exducer: 96mm
47 trim
14 blades
Turbine
Inducer: 85mm
Exducer: 78mm
10 blades
Holset HX40
Cummins ISC
Compressor
Inducer: 60mm
Exducer: 86mm
14 blades
NOTE: Same as the HE351 and HE351VE
Turbine
Inducer: ??mm
Exducer: ??mm
?? blades
Holset HX55 (4036892)
Cummins ISX Signature 450
Compressor
Inducer: 69.35mm
Exducer: 98mm
50 trim
14 blades
Turbine
Inducer: 85.8mm
Exducer: 79.6mm
12 blades
Old 11-23-2011, 04:58 PM
Default Update
Added Holset HE221W
Cummins ISBe 3.9 and ISF 2.8, Brazilian Ford F-250 (2006-current)
Compressor
Exducer: 60mm
Inducer: 43.5mm
12 blades
52 trim
Turbine
Inducer: 53mm
Exducer: 45.7mm
11 blades
Old 01-16-2012, 05:30 PM
Discussion of the HE221W is in this thread: ForcedInduction's Holset HE221 Turbo
Old 08-28-2012, 07:27 PM
Default Thanks for the info.
Gene Panasenko
Old 11-02-2012, 04:23 AM
The updated Holset product overview as of Mid-2012.
LinkBacks (?)
LinkBack to this Thread: http://mercedesforum.com/forum/diesel-performance-49/turbocharger-information-vnt-wastegated-48071/
Posted By For Type Date
300D Turbo identification - Benzworld.org - Mercedes-Benz Discussion Forum This thread Refback 02-24-2013 10:26 AM
What turbo is this? (Holset content inside) This thread Refback 08-23-2012 03:53 PM
Thread Thread Starter Forum Replies Last Post
ForcedInduction's GT2356V hybrid VNT turbo ForcedInduction Diesel Performance 20 09-14-2012 02:26 AM
VNT/VGT turbo control based on engine load ForcedInduction Diesel Performance 0 10-10-2011 04:13 PM
GT2256V VNT Turbo on an OM617 ForcedInduction Diesel Discussions 4 02-07-2007 12:36 AM
SUPERCHARGER/TURBOCHARGER FOR SALE alexandr230 For Sale / Trade Classifieds 0 12-15-2005 05:39 PM
SUPERCHARGER/TURBOCHARGER FOR SALE JUST $400. alexandr230 For Sale / Trade Classifieds 0 11-16-2005 05:06 AM
Tags
20022006, airesearch, benz, borg, bv50, cummins, he551v, holset, isl, isx, mercedes, t3, turbo, turbocharger, warner
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
