Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance - Page 6 - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
  #51
Old 04-06-2016, 12:01 AM
ForcedInduction's Avatar
Quote:
Originally Posted by Nifty View Post
I am surprised that Mercedes did not change the engine designation as they are so careful with part numbers.
They did. The .91x and .95x are very different engines inside.
Quote:
Anyway we are only getting around 200C temperature
Your gauge is not accurate or your sensor is in a bad location. That is just slightly above what the engine exhaust temperature is at idle.
  #52
Old 05-08-2016, 10:41 AM
Hi ForcedInduction,
I have a 1984 300SD I really love and like to get some performance mods done. Can you recommend any reliable shops who is taking on jobs like this.
Thank you,
Kornel
  #53
Old 05-08-2016, 10:54 PM
None. No shops will take custom engine modification jobs.
Three reasons;
The car is too old for current techs to have any knowledge (or interest) in working on it.
Zero non-stock parts exist (that actually work). ALL modifications will require substantial manual labor and cost.
All modern cars are computerized. Most diesel injection shops are either out of business or sold off their pump test benches because mechanical pumps like these just don't exist in the wild in large enough numbers to be profitable anymore.
These are enthusiast cars. You'll have to plan on doing nearly all modifications, maintenance and repairs yourself, otherwise you will very quickly spend more than the car is worth and it still won't be any faster than anything with a V6 from the 1990's+.
About the only places you'll find are some exhaust shops that will make a custom exhaust system, but the stock exhaust is already very good unless you're shooting for 300+hp.
  #54
Old 11-10-2016, 03:14 PM
Default om617 pump help
I followed the directions to removing the gov limiter and now when I start the car it literally runs wide open and the fuel shut off wont even kill it. I did not adjust anything else in the pump. any help would be greatly appreciated guys
  #55
Old 11-10-2016, 09:51 PM
Make sure the shutoff actuator arm is hooked in front of the rack and not pushing on it.
  #56
Old 12-13-2016, 08:00 AM
Can the Control Rod Travel Sensor be removed through the vacuum stop opening? Is there any complication to removing it other than the 2 screws on the side of the pump and the ring on the top?
I had seen a post awhile ago regarding replacing the O ring on the stop lever. Well a week later (relying on my memory, big mistake) I removed the lever and proceeded to remove the hollow bolt that holds it in place as well. No I did not remove the clip behind the stop lever first, as I mentioned above I was going by memory.
I recognized my mistake and went to reassemble it. The shaft is now loose (in and out) in the housing. I pulled the vacuum shut-off and realigned the peg back into its slot on the internal arm of the shaft but I had to use a thicker washer to bring it back to normal. Now the vehicle has no power while driving. At idle in park or neutral the motor performs as normal and shuts off as normal.
What else does the stop lever shaft attach to that would cause this lack of performance? Does anyone have an exploded view of what the internals of that part of the pump is supposed to look like?
I may have bent the slotted arm at the end of the shaft when removing the hollow securing nut.
I was able to get the shaft of the stop lever out of my spare injection pump to swap it out. However I could not get the one out that is on my motor as it still had the Fuel rack travel sensor still in the head of the IP.
I am concerned that when I initially turned the large hollow nut against the resistance of the securing clip it caused the stop lever to push to far forward and perhaps damage parts in the circled area.
Any help on this is greatly appreciated.
OM603 pump 87 E300 with # 18 head
LinkBacks (?)
LinkBack to this Thread: http://mercedesforum.com/forum/diesel-performance-49/injection-pump-fuel-adjustment-mw-m-pumps-engine-tuning-maintenance-46097/
Posted By For Type Date
W124 E300D OM606 engine wiring harness - Page 4 - Mercedes-Benz Owners' Forums This thread Refback 09-18-2013 03:46 AM
Help me settle an argument - Diesel Bombers This thread Refback 09-09-2013 06:30 PM
om617 rack limiter removale. - Diesel Bombers This thread Refback 08-17-2013 03:00 PM
Mersuforum.net • katso viestiketjua - OM603 stock pump power This thread Refback 07-13-2013 07:07 AM
MODDERPOEL • Toon onderwerp - Turbodruk This thread Refback 05-26-2013 05:13 AM
240D Auto, Searching for cause of low power - Page 3 - Benzworld.org - Mercedes-Benz Discussion Forum This thread Pingback 08-26-2011 08:42 AM
93 300D maintenance question - PeachParts Mercedes ShopForum This thread Refback 08-25-2011 04:44 PM
The never ending performance quest.... - PeachParts Mercedes ShopForum This thread Refback 08-25-2011 10:45 AM
Correct Fan Clutch for 11 Blade Plastic Fan? - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 09:05 PM
Need precombustion chamber seals... - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 08:45 PM
93 300D maintenance question - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 07:48 PM
Diesel purge- second container for return? - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 01:31 PM
'93 W124 300D ALDA Removal Suggestions - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 12:53 AM
Superior Shift Kit 300SD - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 06:29 PM
From "Norm" to "Turbo Norm" - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 05:12 AM
Actual A/C ΔT that most obtain - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 01:33 AM
FS HE341 - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-22-2011 02:52 PM
Bad news - PeachParts Mercedes ShopForum This thread Refback 08-22-2011 10:38 AM
Water-Methanol injection - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 10:18 PM
Synthetic oil: Diesel mechanic says no - Page 8 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 01:49 PM
is this temperature too high? - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 08:14 AM
Synthetic oil: Diesel mechanic says no - Page 7 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 12:11 AM
280 SL with 617Turbo Diesel on Ebay - PeachParts Mercedes ShopForum This thread Refback 08-17-2011 02:08 AM
Can someone look at this? - PeachParts Mercedes ShopForum This thread Refback 08-16-2011 09:33 PM
Synthetic oil: Diesel mechanic says no - Page 4 - PeachParts Mercedes ShopForum This thread Refback 08-16-2011 05:51 AM
PeachParts Mercedes ShopForum - View Single Post - FS HE341 This thread Refback 08-15-2011 03:57 PM
Using Autologic or SDS to tune EGR settings on a bluetec - PeachParts Mercedes ShopForum This thread Refback 08-15-2011 10:10 AM
Interesting High Altitude 617.950 Behavior: - PeachParts Mercedes ShopForum This thread Refback 08-15-2011 02:34 AM
What's wrong with this picture? - Page 11 - PeachParts Mercedes ShopForum This thread Refback 08-14-2011 02:03 AM
300D Turbo at 5,000 feet - Page 6 - PeachParts Mercedes ShopForum This thread Refback 08-13-2011 04:04 PM
1987 300d somethings not right..? - Page 3 - PeachParts Mercedes ShopForum This thread Refback 08-13-2011 11:39 AM
Off-Road Diesel - Who Enforces That It Not Be Used Over The Road? - Page 6 - PeachParts Mercedes ShopForum This thread Refback 08-12-2011 08:28 AM
1987 300d somethings not right..? - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 10:15 PM
OM617 turbo/non-turbo cylinder head differences? - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 01:37 PM
Differential Fluid - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 11:41 AM
Meyle v. Febi SLS Suspension Fluid - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 01:45 AM
Euro IP vs US IP - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 10:20 PM
Oil cooler line replacement - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 07:07 PM
propane injection - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 12:31 PM
Bringing A/C pressures down 300TE - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 08:11 AM
FS HE341 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 06:52 AM
Safe, I hope, Oil Question - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 12:53 AM
mobil 1 in a 300TD - PeachParts Mercedes ShopForum This thread Refback 08-09-2011 02:21 PM
High Boost Atmospheric BOV Turbo Dump Valve - PeachParts Mercedes ShopForum This thread Refback 08-09-2011 11:33 AM
clubgwagen.com • View topic - Some extra HP This thread Refback 07-11-2011 12:12 AM
Mercedes 190d - Competition Diesel.Com - Bringing The BEST Together This thread Refback 05-09-2011 03:18 PM
Diesel Horsepower | Mercedes-Benz Club of America This thread Refback 05-07-2011 12:00 PM
300D Turbo size - Competition Diesel.Com - Bringing The BEST Together This thread Refback 04-10-2011 01:35 PM
IP Full Load Adjustment Procedure for the MW and M pumps, pyrometer install This thread Refback 04-06-2011 07:56 PM
basic performance upgrades - Benzworld.org - Mercedes-Benz Discussion Forum This thread Pingback 03-22-2011 02:04 AM
Thread Thread Starter Forum Replies Last Post
1988 420 sel fuel pump or pumps? dado1968 General Tech 0 04-27-2012 02:34 AM
Replacing Fuel pumps on a W126 BlackWolf Mercedes S Class 0 07-31-2009 10:47 AM
Cost of Labor for replacing Fuel Pumps ahyat General Tech 3 06-14-2008 05:49 PM
injection pump tuning juggernaut General Tech 20 03-11-2007 07:35 PM
Looking for someone who repairs older injection pumps mesmeralda General Tech 0 10-19-2006 09:38 PM
Tags
adjust, adjustment, diesel, fuel, injection, injector, inline, limiter, mercedes, mercedesbenz, modification, mw, om617, pump, pyrometer, rack
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
