Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance - Page 2 - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
  #11
Old 04-03-2012, 08:16 PM
Quote:
Originally Posted by ForcedInduction View Post
The ALDA is an emissions control device and overload protection. If you remove it the engine can be damaged if the wastegate hose fails.
Oh interesting, so are there any performance gains from removing it?
  #12
Old 04-03-2012, 08:42 PM
ForcedInduction's Avatar
None when its correctly adjusted. Only smoke.
It should be adjusted to where there is no visible smoke when the throttle is mashed from a standstill.
  #13
Old 04-03-2012, 09:09 PM
But there should be a small amount of smoke if you rev it in neutral right?
  #14
Old 04-03-2012, 09:14 PM
None.
  #15
Old 04-03-2012, 09:53 PM
None.
Oh ok, so you just turn it up until there is a little smoke then slowly back it off until there isn't any?
  #16
Old 04-03-2012, 10:06 PM
Yep, thats all there is to it!
  #17
Old 04-04-2012, 08:35 PM
Well I attempted to adjust the ALDA today, I loosened the nut and turned the screw all the way in both directions and it made little to no difference to the amount of smoke when I rev the engine(which is alot) do you have to be driving to see any difference, because I was only doing this in neutral?
Also another thing I was wondering, I have all the EGR stuff still on the engine but no vacuum to it, does that make the EGR valve stay closed all the time as long as its working correctly and not leaking?
The engine starts and runs fine I'm just trying to get everything adjusted back to tip top shape, anything else I should check?
  #18
Old 04-04-2012, 09:29 PM
Quote:
Yes, the engine must have a load.
Most of the time. Exhaust pressure can still push it open in some cases.
  #19
Old 05-14-2013, 01:01 AM
Default Diesel Mechanic
Hi ForcedInduction,
Sorry to be so lazy but I am always short on time so I would like to steal some of yours.
They say I am a diesel mechanic but I guess it depends on who you talk to.
A few questions if you don't mind; (if you don't know off the top of your head don't waste your time looking something up for me). Most of my diesel experience is Cummins, International, Detroit, CAT, you get the idea, so you kind of know where I am coming from.
Car is a 1986 300sdl. 6 cylinder.
1. Inlet Fuel pressure; adjustable? how much? and is it like a Cummins 12V, too much is too much!
2. What turbo do I have? I'm guessing it's a t3 but looking for some verification. VGT? Wastegated or a blowoff?
3. Injection pump model#? can it be adjusted same as the 5 cyl. ones you have gone over in your other threads? Is the timing adjustable like a bosch p pump on a Cummins 12V? I have the timimg tools kit to adjust the Cummins but not a clue what the lift to degrees correspondence would be for a Mercedes. If it is adjustable how much is optimum? Right now I am running my Dodge Cummins at 19.5 degrees but I think the only reason I am getting away with that is the gears have so much play in them, 400K miles.
4. The boost pressures your recommending are low compared to what I am used to. Are these motors known for head gasket problems?
Any info or insite would be appreciated. Car is currently a daily driver.
Thanks, Paul
  #20
Old 05-14-2013, 07:37 AM
1. Up to 30psi. More is not needed. Not adjustable.
2. T3-50
3. PES 6 M 55 C 320 RS, yes, adjustment is identical as the "W124" pictured. Timing is adjusted by following this: http://www.furi-dorifto.com/tech/MB_.../07.1-8300.pdf
4. High boost is not needed on these engines. Cummins need high boost to make power because they have a very low RPM limit, that means they need lots of torque to make little horsepower. These engines have a very high RPM limit (4800rpm) so they don't need lots of torque to make horsepower.
LinkBacks (?)
LinkBack to this Thread: http://mercedesforum.com/forum/diesel-performance-49/injection-pump-fuel-adjustment-mw-m-pumps-engine-tuning-maintenance-46097/
Posted By For Type Date
W124 E300D OM606 engine wiring harness - Page 4 - Mercedes-Benz Owners' Forums This thread Refback 09-18-2013 03:46 AM
Help me settle an argument - Diesel Bombers This thread Refback 09-09-2013 06:30 PM
om617 rack limiter removale. - Diesel Bombers This thread Refback 08-17-2013 03:00 PM
Mersuforum.net • katso viestiketjua - OM603 stock pump power This thread Refback 07-13-2013 07:07 AM
MODDERPOEL • Toon onderwerp - Turbodruk This thread Refback 05-26-2013 05:13 AM
240D Auto, Searching for cause of low power - Page 3 - Benzworld.org - Mercedes-Benz Discussion Forum This thread Pingback 08-26-2011 08:42 AM
93 300D maintenance question - PeachParts Mercedes ShopForum This thread Refback 08-25-2011 04:44 PM
The never ending performance quest.... - PeachParts Mercedes ShopForum This thread Refback 08-25-2011 10:45 AM
Correct Fan Clutch for 11 Blade Plastic Fan? - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 09:05 PM
Need precombustion chamber seals... - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 08:45 PM
93 300D maintenance question - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 07:48 PM
Diesel purge- second container for return? - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 01:31 PM
'93 W124 300D ALDA Removal Suggestions - PeachParts Mercedes ShopForum This thread Refback 08-24-2011 12:53 AM
Superior Shift Kit 300SD - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 06:29 PM
From "Norm" to "Turbo Norm" - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 05:12 AM
Actual A/C ΔT that most obtain - PeachParts Mercedes ShopForum This thread Refback 08-23-2011 01:33 AM
FS HE341 - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-22-2011 02:52 PM
Bad news - PeachParts Mercedes ShopForum This thread Refback 08-22-2011 10:38 AM
Water-Methanol injection - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 10:18 PM
Synthetic oil: Diesel mechanic says no - Page 8 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 01:49 PM
is this temperature too high? - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 08:14 AM
Synthetic oil: Diesel mechanic says no - Page 7 - PeachParts Mercedes ShopForum This thread Refback 08-18-2011 12:11 AM
280 SL with 617Turbo Diesel on Ebay - PeachParts Mercedes ShopForum This thread Refback 08-17-2011 02:08 AM
Can someone look at this? - PeachParts Mercedes ShopForum This thread Refback 08-16-2011 09:33 PM
Synthetic oil: Diesel mechanic says no - Page 4 - PeachParts Mercedes ShopForum This thread Refback 08-16-2011 05:51 AM
PeachParts Mercedes ShopForum - View Single Post - FS HE341 This thread Refback 08-15-2011 03:57 PM
Using Autologic or SDS to tune EGR settings on a bluetec - PeachParts Mercedes ShopForum This thread Refback 08-15-2011 10:10 AM
Interesting High Altitude 617.950 Behavior: - PeachParts Mercedes ShopForum This thread Refback 08-15-2011 02:34 AM
What's wrong with this picture? - Page 11 - PeachParts Mercedes ShopForum This thread Refback 08-14-2011 02:03 AM
300D Turbo at 5,000 feet - Page 6 - PeachParts Mercedes ShopForum This thread Refback 08-13-2011 04:04 PM
1987 300d somethings not right..? - Page 3 - PeachParts Mercedes ShopForum This thread Refback 08-13-2011 11:39 AM
Off-Road Diesel - Who Enforces That It Not Be Used Over The Road? - Page 6 - PeachParts Mercedes ShopForum This thread Refback 08-12-2011 08:28 AM
1987 300d somethings not right..? - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 10:15 PM
OM617 turbo/non-turbo cylinder head differences? - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 01:37 PM
Differential Fluid - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 11:41 AM
Meyle v. Febi SLS Suspension Fluid - PeachParts Mercedes ShopForum This thread Refback 08-11-2011 01:45 AM
Euro IP vs US IP - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 10:20 PM
Oil cooler line replacement - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 07:07 PM
propane injection - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 12:31 PM
Bringing A/C pressures down 300TE - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 08:11 AM
FS HE341 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 06:52 AM
Safe, I hope, Oil Question - Page 2 - PeachParts Mercedes ShopForum This thread Refback 08-10-2011 12:53 AM
mobil 1 in a 300TD - PeachParts Mercedes ShopForum This thread Refback 08-09-2011 02:21 PM
High Boost Atmospheric BOV Turbo Dump Valve - PeachParts Mercedes ShopForum This thread Refback 08-09-2011 11:33 AM
clubgwagen.com • View topic - Some extra HP This thread Refback 07-11-2011 12:12 AM
Mercedes 190d - Competition Diesel.Com - Bringing The BEST Together This thread Refback 05-09-2011 03:18 PM
Diesel Horsepower | Mercedes-Benz Club of America This thread Refback 05-07-2011 12:00 PM
300D Turbo size - Competition Diesel.Com - Bringing The BEST Together This thread Refback 04-10-2011 01:35 PM
IP Full Load Adjustment Procedure for the MW and M pumps, pyrometer install This thread Refback 04-06-2011 07:56 PM
basic performance upgrades - Benzworld.org - Mercedes-Benz Discussion Forum This thread Pingback 03-22-2011 02:04 AM
Thread Thread Starter Forum Replies Last Post
1988 420 sel fuel pump or pumps? dado1968 General Tech 0 04-27-2012 02:34 AM
Replacing Fuel pumps on a W126 BlackWolf Mercedes S Class 0 07-31-2009 10:47 AM
Cost of Labor for replacing Fuel Pumps ahyat General Tech 3 06-14-2008 05:49 PM
injection pump tuning juggernaut General Tech 20 03-11-2007 07:35 PM
Looking for someone who repairs older injection pumps mesmeralda General Tech 0 10-19-2006 09:38 PM
Tags
adjust, adjustment, diesel, fuel, injection, injector, inline, limiter, mercedes, mercedesbenz, modification, mw, om617, pump, pyrometer, rack
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
