Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Diesel Performance
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Mercedes Forum today!
LinkBack Thread Tools Search this Thread
Old 05-24-2011, 08:52 PM
ForcedInduction's Avatar
Default ForcedInduction's GT2356V hybrid VNT turbo
After 5 years of use my GT2256V was starting to show its age, bypassing some oil on the compressor side and occasionally making a *woo* sound when it spooled up from idle.
Having a GT2359V from an E320 CDI on my shelf, I decided to combine the best of both worlds into a hybrid turbo. And the GT2356V hybrid VNT was born.
Great exhaust flow of the GT23 turbine with the well matched flow characteristics (to an OM617) of the 56mm GT22 compressor.
Click the image to open in full size.
I had to make a new adapter plate due to orientation differences between the Sprinter and E320 turbos. The Sprinter flange requires a slight upward tilt for the turbo's outlet flange to be level where the E320 is square with the T3 flange. The rearward stud on the adapter plate is longer to accommodate the intercooler's support bracket.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Spool up speed is nearly the same thanks to it's VNT design.
The exhaust backpressure : boost ratio is now always close to 1:1 across the RPM range, the GT22 turbine was 1.5:1 most of the time and rose to 2.5:1 on the top-end.
I got rid of the flex tubes that coupled the GT22 outlet to the exhaust, it was a constant leak issue trying to seal the thin metal with a clamp designed for pipe. The outlet pipe is now a 3" od-od coupler pipe welded directly to the turbine outlet and downpipe flange, with the flange being bell-mouthed to improve flow stability.
That also got rid of the support bracket that bolted to the manifold, reducing heat conduction loss from the manifold to downpipe. Here the exhaust manifold pressure (EMP) pipe can be seen.
The only down side so far is its louder at idle, both with vanes open and closed. Sound level measures 84db at full power at 70mph, thats with the shorty pipe outlet at the passenger door and windows up.
Its been raining pretty consistently the last few days, so my water injection system is not able to work (vaporize) as effectively as it can. Once the weather warms up and dries up I will get a dyno run to determine what kind of power gains I got from the improved EMP:boost ratio. Stay tuned!
Register today for free or log in if already registered to remove this ad!
Old 05-31-2011, 09:07 PM
0-60mph. 10.5s from idle, 10.0s powerbrake with some wheel spin off the line.
YouTube - 300D 0-60mph tests, GT2356V hybrid
Old 06-05-2011, 06:26 PM
I have a new solution to the low-rpm surge problem that eventually wore out the 2256.
Bob Myers makes an electronic drop-in replacement for the stock tach amplifier. He will be programming one to trigger a vacuum solenoid from 0-2300rpm, that will control an air recirculation valve (ARV) to dump intake air from the manifold back to the turbo inlet via 3/4" hose. The valve to be used is a common air injection shutoff valve used on pretty much every g@sser W126 model.
This will increase the effective displacement of the engine by roughly 20% and bring airflow to the right of the surge line.
The graph below shows airflow at my altitude of 5200' from 1500-2300rpm at the 4, 10 and 13psi stages.
Red= no recirculation
Green= recirculation
Blue = recirculation w/water injection
If this works out there will no longer be any need to pursue an 1800rpm stall speed torque converter.
Old 06-10-2011, 09:04 PM
The valve is installed with a few alterations.
Bench testing found the valve can't hold more than 10psi without leaking. To counter this I made the vent side of the control solenoid open to manifold pressure with a check valve to prevent air constantly flowing in-out of the valve.
Water injection is disabled with the valve open to prevent water getting into the turbo's control system.
A light in the cluster was added to show when its open.
A manual switch was added to disable operation if desired.
The valve flows too much air when open, drive pressure is high and boost is very slow to build even at high throttle rates. I will modify the ARV with a stop screw to limit valve lift.
There is too much air flow noise, I will install a muffler from a Ford's Air injection system.
Old 08-09-2011, 01:13 AM
Two changes; A restriction orifice of 3/8" was added to reduce unnecessary airflow loss and a muffler (From a 90's Ford pickup AIR injection system) was added to eliminate flow noise.
Old 01-16-2012, 04:09 PM
This turbo and ARV has been moved to my 240D.
Old 09-01-2012, 06:45 PM
Default What is your Final analysis
on this valve? Any noticable improvement after revisions?
Old 09-01-2012, 09:50 PM
Garret's compressor wheels are designed for gasoline engines. Its a good, very fast spooling turbo, but it spools too fast for an OM617 and surges below 2000rpm. The ARV was a good compromise but ultimately not what I was really happy living with.
The Holset I have now is a much better turbo all-round; more efficient, better quality, more durable. All it needs is a VGT turbine, which Holset announced this year and should start producing any time. As soon as I can find a part number I'll buy one new.
  #9
Old 09-02-2012, 10:31 PM
I will be very interested to see you run one when they come out, sounds like it could potentially be the perfect turbo for these engines, but I guess there will be a controller involved. Your controller seems to be the best I've read about, but I was hoping an IC based one would come around for us to copy or buy. Thanks to you I have learned an immense amount about turbos overall and even more specifically pertaining to the 617, but I'm hesitant to replicate the analog controller due to complexity at least for now. But I appreciate yoru posts.
  #10
Old 09-03-2012, 05:50 AM
Its not complex at all. Its just 3 ball-spring regulators like used with normal turbos (manual boost controllers), two roller valves and a vacuum actuator. The valves could easily be substituted with electrical roller switches and vacuum solenoids but I wanted to make it electricity-free for simplicity and reliability.
Somebody has designed an arduino based electronic controller.
dmn's playground - Standalone VNT controller
I was tempted to try it, but I prefer to keep away from electrics as much as possible.
Tags
arv, booster, diesel, forcedinductions, gt23, gt2356v, gt2359v, hybrid, mercedes, om617, perform, problems, solenoid, turbina, turbo, valve, vnt
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
