C111-IId and C111-III details from Mercedes - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 12-17-2010, 07:09 AM
ForcedInduction's Avatar
Default C111-IId and C111-III details from Mercedes
Contact:
Josef Ernst Phone: +49 (0) 711/17-7 64 77
Mobile: +49 (0) 160/86 19 898
Date:
April 2008
Press Information
Mercedes-Benz C 111-III record-setting car Stuttgart. Punctually at midnight on April 30, 1978, the five pistons in the diesel engine of the Mercedes-Benz C 111-III began to work, supported by an intercooled exhaust gas turbocharger which, at 130,000 revolutions per minute, pressed enough air into the combustion chambers to boost the output to 169 kW/230 hp. That was more than enough power for accelerating the Mercedes-Benz in record-hunting trim to a top speed of around 325 km/h. Because of its very “long” ratio, the car did take its time, however – a complete 12.66 kilometer lap of the circuit in Nardo in southern Italy, to be precise - to reach this speed.
A Wankel engine for large-scale production?
What sort of cars were the Mercedes-Benz experimental models C 111 to C 111-IV? In the late nineteen-sixties, the development engineers had set their sights on testing the Wankel engine on which Daimler-Benz was working at the time with the declared aim of incorporating it in production cars. The C 111 was to serve as a research car for testing Wankel engines, new suspension components for wider tires through to racing tires and plastic bodywork components. In addition, the C 111 was used to improve the aerodynamic efficiency of sporty road-going cars.
The three-rotor Wankel engine in the first C 111 of 1969 developed 206 kW/ 280 hp, giving the car a top speed of around 260 km/h. The Daimler Communications, 70546 Stuttgart/Germany newcomer set out on its first tests in Untertürkheim, on the Hockenheimring and the Nürburgring in April and May 1969. The suspension featured anti-squat and anti-dive control; its front axle components were incorporated in large-scale production at a later stage and the rear axle was a precursor of today’s multi-link independent rear suspension. On the basis of the experience gained in testing this car, another five experimental cars were built. They all provided the level of comfort with which a road-going Mercedes-Benz sports car should spoil its buyers. The experimental cars were shown to journalists, engineers and contemporary VIPs at the time of the 1969 IAA, albeit at a different location. Only five months later, an experimental car designated C 111-II was fitted with a four-rotor Wankel engine with an output of 258 kW/350 hp: it gave the car a top speed of 300 km/h and accelerated it from standstill to 100 km/h in 4.8 seconds. Compared to the C 111-I, this version had a bodywork that had been improved significantly in terms of vision for the driver as well as aerodynamic efficiency – the Cd was 0.325, not bad at the time. The most important aspects, however, were the clearly improved flexibility of the Wankel engine and its torque raised to 40 mkg; this meant that no contemporary road-going car would have been a match for the C 111-II.
The company introduced that car to the broad public at the Geneva Motor Show in March 1970. Like the first version, it immediately became an object of desire for all those fans of the brand who were longing for a spectacular successor to the 300 SL Gullwing coupe. But hopes were destroyed by ever more stringent emission legislation in a large number of countries and finally by the 1973 oil crisis, because the pollutant emissions of Wankel engines were difficult to reduce, and they also had a relatively high fuel consumption – far from meeting the demands of the time.
Racing diesel in keeping with the times
Once the first shock of the oil crisis had been overcome, the Wankel engine was replaced by a diesel engine – a policy pursued by the entire industry since the diesel was known to be economical. On the other hand, it was also generally known to be a lame duck – a view that was not completely unjustified. Something had to be done about it, and the development engineers and Board of Management came up with the idea of establishing sales-promoting diesel records. The basic engine which suggested itself was the powerful, five-cylinder three-liter naturally aspirated diesel from the 240 D 3.0 and 300 D, an engine with plenty of potential for raising performance. With a Garret turbocharger and an intercooler, the production engine’s output of 80 hp was boosted to a proud 140 kW/190 hp to power the C 111-IID, revamped into a diesel-engined record car, in the record run on the brand-new test track in Nardo on June 12, 1976. The four drivers, who took turns at two-and-a-half hour intervals, drove this car from one diesel record to the next over a time-span of 60 hours, completed without any problems. In the end, a total of 16 new records had been established – those over 5,000 miles, 10,000 kilometers and 10,000 miles even were absolute world records, i.e. independent of the type of engine. Speed averaged around 252 km/h. So the diesel had proved its ability to race, and with a suitable ratio, the C 111-IID completed the sprint from standstill to 100 km/h in just 6.8 seconds.
The records established by the C 111-III
For those involved in the project, this was just the beginning, however. They knew they could have made the car even faster, raising its top Daimler Communications, 70546 Stuttgart/Germany speed to over 300 km/h, but had to admit that this was meant for an aerodynamically optimized “proper” racing car rather than for a road- going version of the C 111. The Board of Management at the time has to be credited for sharing this view and giving the go-ahead for development. The design department set about its task in early 1977 and created the C111-III on the basis of the C 111 team’s specifications – a thoroughbred racing car with aerodynamic features refined down to the smallest detail and giving the car a Cd value of 0.183, the lowest rating ever achieved up to that point in time. The car had a longer wheelbase than the C 111-II, a narrower track, concealed wheels, a very low front end with recessed, powerful headlamps and a very long and tapering rear end with a central fin that was to enhance the car’s straightline stability under side wind conditions.
The long and narrow driver’s compartment featured a single seat: the front passenger’s space was occupied by a fat pipe conducting air into the intercooler. And there was also room for the telemetry system, specially developed by Mercedes-Benz for automatic data transmission during the record runs, as well as for radio equipment, enabling the driver to communicate with the team on the move. And finally, on April 30, 1978, the time had come for the diesel- engined record car to drive lap after lap at constant speed on the Nardo track – anti-clockwise because this meant that the track- defining crash barriers were on the right-hand side, providing the drivers of the LHD cars with a greater safety margin in the event of an accident. At one stage during the night, radio communication saved a hedgehog’s life: it was rescued in time before crossing the racing car’s Daimler Communications, 70546 Stuttgart/Germany lane. When the rear tire on the right-hand side burst during the third driver’s stint at night-time, tearing large holes into the bodywork, the recovery truck arrived on the scene quickly to pick up the damaged car and its uninjured driver, while the mechanics prepared the identical reserve car. After this incident, clocks were reset to zero and the hunt for records began anew. The reserve car was even a whisker faster than the original car, and also a little more economical, extending the refueling intervals from 62 to 67 laps. The three drivers were soon joined and relieved by their extremely fast project manager, Dr. Hans Liebold. All records established by the time of the tire damage were repeated at even better times, and the attempt was not even jeopardized by another hedgehog which was unfortunate enough to get in the record car’s way and ruined its front spoiler. The repair took no more than two minutes. The pit stops, incidentally, lasted between 15 and 20 seconds – the refueling, driver changes, tire checks and topping up of oil had all been meticulously planned and thoroughly practiced. After 12 hours of otherwise problem-free driving, the Mercedes-Benz brand had established nine absolute world records independent of engine type and displacement – achieved with a near-production three-liter diesel engine. At the end of the day, the engine in the record car had consumed just less than 16 liters per 100 kilometers (17.66mpg) – another outstanding record given an average speed of over 300 km/h.
The world records established by the diesel-engined C 111-III
100 km 316.484 km/h
100 miles 319.835 km/h
500 km 321.860 km/h
500 miles 320.788 km/h
1000 km 318.308 km/h
1000 miles 319.091 km/h
1 hour 321.843 km/h
6 hours 317.976 km/h
12 hours 314.463 km/h
World circuit record: 403.978 km/h
A world circuit record of 355.854 km/h had been in existence since 1975, established by a 1,000 hp racing car from the American Can-Am series. Though not recognized by FIA, it was a highly desirable world record, and after the successes with the C 111-III, the Mercedes-Benz engineers felt that it was within reach. Just another 100 hp would do – but could no longer be squeezed out of the near-production diesel. So the team opted for the 4.5 liter V8 gasoline engine from large-scale production, raised its displacement to 4.8 liters and equipped the unit with sodium-cooled valves, two KKK turbochargers and a triple-plate clutch that was capable of coping with 600 Newtonmeters of torque.
With 368 kW/500 hp under the hood, achieved at relatively low expense, a C 111-IV modified into a racing car with further aerodynamic improvements, two fins and additional spoilers set out in Nardo on May 5, 1979 to have a go at the world circuit record. After a smooth run, a new record of 403.978 km/h had been established. Over and above this, the car improved upon the record marks over ten and 100 kilometers as well as over ten and 100 miles.
Further information from Daimler is available on the internet at:
www.media.daimler.com
Old 12-17-2010, 07:11 AM
Default C111-iid
Mercedes-Benz C 111 - II D record car, 1976
Diesel-engined record car, based on the Wankel-engined experimental car
In the mid-seventies, the Daimler-Benz AG decided to launch the new turbocharged Diesel engine OM 617 A on the
American market as the S-Class power unit. However, due to the lame-duck image of the Diesel, it was doubted that a car
with such a drive would be accepted in the USA. This is how the idea of record trial with this engine was born. The 1970 C
111 - II was reactivated for the record trial which was to take place at Nardo, Italy. It was piloted by the members of the
testing department, Dr. Hans Liebold, Joachim Kaaden, Erich Waxenberger and Guido Moch. The trial was a great success.
Engine type: OM 617 LA
Inlet valves: 1 overhead valve per cylinder, actuated via finger follower
Ignition sequence: 1-2-4-5-3
No. of cylinders / arrangement 5 / in line
Outlet valves: 1 overhead valve per cylinder, actuated via finger follower
Configuration: In front of rear axle, longitudinal; vertical
Valve operation: 1 overhead camshaft, double roller chain drive
Combustion principle: Four-stroke Diesel (with indirect injection, Garrett turbocharger, charge-air cooling)
Crankshaft: 6-bearing
Bore x Stroke: 90.9 x 92.4 mm
Fuel system: Indirect injection, Bosch 5-plunger injection pump
Total displacement: 2999 cc
Spark plugs: 1 glow plug per cylinder
Fuel supply: 2 electrical pumps
Compression ratio: approx. 21
Fuel tank capacity: 140 l
Maximum / output / rated output: 190 hp at 4200-4700 /min
Rated torque: 363 Nm at 3500 /min (268lb/ft)
Cooling: Water circulation cooling
Lubrication: Pressure circulation lubrication
Cylinders: Gray cast iron block
Cylinder head: Light alloy, removable
Starter: Electrical, Bosch
Ignition: Compression ignition
Foot brake: Acting on front- and rear wheels
Steering: Recirculating-ball steering
Wheels: Light-alloy wheels
Front tires: 215/70 VR 15 Michelin XVR
Frame design: Structural floor assembly, welded sheet steel
Rear tires: 215/70 VR 15 Michelin XVR
Front wheel suspension: Double wishbone, suspension struts, torsion bar stabilizer
Drivetrain: Direct transmission from engine-transaxle unit to rear wheels
Rear wheel suspension: 3 wishbones and 2 trailing arms per wheel, suspension struts, torsion bar stabilizer
Brake system: Hydraulically actuated dual-circuit brake system
Front brakes: Internally ventilated disc brakes
Rear brakes: Internally ventilated disc brakes
Transmission: ZF 5-speed manual transmission in unit with differential gear, mounted behind rear axle
Shifting: Center shift
Clutch: Dry double-disc clutch
Transmission type: Change-speed gear
Old 12-17-2010, 07:13 AM
Default C111-iii
Mercedes-Benz C 111 - III record car, 1977 / 1978
Record car based on the C 111-II
As a result of the successful C 111 - II D trial at Nardo in 1976, a new record car was designed in Sindelfingen under the
direction of Prof. Hans Scherenberg. This car was to be powered by the tuned-up OM 617 A supercharged Diesel engine.
The test trial at Nardo began on 30 April 1978 under the direction of Professor Scherenberg's successor Dr. Werner
Breitschwerdt. Like the 1976 trial, it was crowned with success.
No. of cylinders / arrangement: 5 / in line
Fuel supply: Bosch piston pump as part of the injection pump
Compression ratio: 17.5
Maximum / output / rated output: 230 hp at 4200-4600 /min
Rated torque: 403 Nm at 3700 /min (297lb/ft)
Front tires: 230/600 x 15 Dunlop
Rear tires: 230/600 x 15 Dunlop
Gear ratios Overall ratio in 5th gear: 1.65
Dimensions and Weights
Maximum speed 325 km/h (201mph)
Wheelbase 2720 mm
Front track 1260 mm
Rear track 1320 mm
Length 5380 mm
Width 1715 mm
Height 1045 mm
Vehicle weight 1400 kg (3,086lbs)
Comments Drag coefficient = 0.183
Engine weight 244 kg (537lbs)
Seats 1
Thread Thread Starter Forum Replies Last Post
FS: 19" OZ Superleggera III CHEAP amgbling For Sale / Trade Classifieds 0 02-19-2007 09:39 PM
19" OZ LEONARDO III WHEELS Mint !!!!! jessebro45 For Sale / Trade Classifieds 0 04-09-2006 01:06 AM
FS: NEW 18" Brabus Monoblock III Multipiece Rims (Set of 4) Roy13420 For Sale / Trade Classifieds 2 05-03-2004 08:51 PM
NEW 18’ Staggered Brabus monoblock III’s Roy13420 For Sale / Trade Classifieds 0 03-24-2004 08:41 AM
Brabus mono III benji8055 For Sale / Trade Classifieds 0 07-22-2003 12:12 AM
Tags
1977, 617a, c111, car, cylinder, diesel, experimental, garage, germany, mercedes, mercedesa, motor, od, om617a, performance, stuttgart
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
