Vacuum parts?
Old 01-28-2017, 03:01 PM
Licensed to kill's Avatar
Default Vacuum parts?
I'm using a 240D for my Model A and want to strip all peripherals that i can do without. I'm sure I will have more questions along this line later, but for now, I have two things that I need clarification on. 1 is the vacuum pot mounted on the top rear of the injection pump right behind the altitude compensator. Plastic, two vacuum lines (I suspect one in, one out) and a link from it to the accelerator arm on the pump. My understanding is that this if to regulate vacuum to the modulator on auto trans, my my engine came from a car with a standard???. Don't see why I would need this unless it does something else engine related (not car related). 2-there is a vacuum "plug" or sensor that screws into the cooling system right where the coolant comes out of the head. Two vacuum lines. I have no idea what it does but think perhaps its a temperature sensor that, if the coolant gets too high with trip a valve in this thing allowing vacuum through to pull the stop switch?? Idunno. Do I need it?. Thanks
Old 01-29-2017, 09:35 PM
So, it appears that the vacuum switch in the cooling system is for the ERG. As near as i can tell, the only vacuum I need for this engine is for the fuel shut off. Yes...No??
Old 01-31-2017, 10:58 PM
Thanks FI, that's what I thought but I hadn't thought of using a manual shutoff. great idea. Thanks again.
PelicanParts.com
05-02-2013 06:57 PM
hughits
05-27-2008 11:06 AM
dbrunelle
09-05-2007 11:13 AM
cam69ss
01-07-2005 05:45 PM
cam69ss
11-15-2004 04:35 PM
Quick Reply: Vacuum parts?
