ignition wont shut car off - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 06-29-2007, 12:11 PM
Default ignition wont shut car off
Just recently my 300CD stopped shutting down when I turn the key off, so I have to open the hood each time and shut it off using the throttle stop. Can anyone tell me how to diagnose/fix this problem?
Old 06-30-2007, 08:29 AM
Default RE: ignition wont shut car off
I experienced a similar problem with my 1995 E300 a few years ago. When I took it to the dealer's they ran some tests and told me the vacuum pump had gone bad. That was replaced, and the problem went away. Other problemsI experienced with the engine not shutting off were hard steering and hard brakes (almost like no power steering, and no power brakes). I hope this helps. My regular mechanic was away at the time, but when I mentioned the symptoms to him after having it repaired, he told me it was probably the vacuum pump. If he had been around at the time, I would not have had to pay the additional $180 or so for the diagnostic tests.
Old 07-06-2007, 02:59 PM
Look around the engine oil filter canister for broken, disconnected vacuum hoses. Trace each hose in that area to confirm no split hoses or dangling hoses. This engine requires vacuum be applied to shut off the fuel. No vacuum, no shutting off of fuel unless the throttle lever is pressed to shut the fuel off. Also, please add the year and type of Mercedes to your signature and/or profile.
Thread Thread Starter Forum Replies Last Post
Engine wont shut off :,( kalebfrog General Tech 2 08-21-2014 07:02 AM
300cd wont shut off catman General Tech 2 01-03-2009 06:31 PM
84' 300D, no dash lights, no brake booster and wont shut off?! *Updated* joe4324 Diesel Discussions 3 11-09-2007 08:55 AM
CAR WONT SHUT OFF!!!!MBZ 82TD spicybabes Diesel Discussions 3 11-07-2007 04:32 AM
Help climate control wont shut off!!! ClkE Mercedes CLK Class 4 06-02-2005 05:09 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
