Clear Transmission Fluid
Old 04-07-2014, 09:40 AM
williala's Avatar
Default Clear Transmission Fluid
I just purchased a 1999 E300 TD with 103,000 miles, to replace the 1999 E300TD that was totaled last week.
Today going through the fluids, I checked the trans fluid and it is clear. No odor or burnt smell, just clear. You can't even see it on the dip stick. When some is placed on a white paper towel, there is just the faintest pinkish tint, which could be residual from the previous fluid.
The trans shifts well and doesn't exhibit any problems.
I've done a search and there didn't seem to be any definitive answer, so I was wondering if anyone knows of any top line ATF that is clear?
Old 04-07-2014, 04:13 PM
N_Jay's Avatar
Guessing the fluid is very old and the pigment has faded from heat. (but not enough heat to burn the fluid.)
Change it and cross your fingers.
Old 04-08-2014, 09:14 AM
williala's Avatar
Yes, I intend to change it just to be on the safe side. Thanks
Old 04-08-2014, 06:53 PM
chassis221's Avatar
I don't think that car has a trans fluid dipstick. unless you purchased one.
Old 04-23-2014, 11:57 AM
oldrebuiltdodge's Avatar
Some hydraulic fluids will work in an automatic transmission (not that you should use them). I would change it, run it a while and change it again, then hope for the best. Using a heavier fluid than transmission fluid can mask some shifting problems due to worn and leaking seals. If you haven't bought it yet, run away!
williala
04-07-2014 09:25 AM
liquid_drop
08-08-2007 04:19 AM
Beanzo
04-05-2004 07:36 PM
dietcookie
03-17-2004 07:04 PM
Taikeson
12-24-2003 03:18 AM
Quick Reply: Clear Transmission Fluid
