Aux fan for A/C - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 05-05-2009, 08:56 PM
Default Aux fan for A/C
What makes the Aux fan for the a/c come on?
Old 05-06-2009, 01:43 AM
ForcedInduction's Avatar
Refrigerant temperature and/or pressure.
Old 05-06-2009, 07:25 AM
The control switch is located on the receiver/drier. It's easy to test if it's working or not.
Old 05-06-2009, 12:30 PM
Quote:
How do you test it, and how is it replaced if it is bad???
Also on note, I don't remember the compresser cycling off and back on, I just remember it coming on when the a/c was selected and going off when we turned it off...
Thanks;
Rod
Old 05-06-2009, 04:39 PM
To test the switch, turn the a/c off, unplug the connections to the switch and attach an ohmmeter to the connections on the switch. The ohmmeter should read that the connection is open. Turn the a/c on high and the switch should close after a little bit and the fan should come on. If the switch closes and your fan still is not coming on after you reconnect it, the problem is between the switch and the fan. Unplug the fan motor connection and put 12v dc power to it and the fan should come on. If it doesn't, then most likely the fan motor is bad. If the switch does not close then either the switch is faulty or your refrigerant level is low.
I do not remember if the a/c system has to be emptied in order to replace the switch or not. I don't think so, but perhaps someone else should chime in here.
Either way, if the switch is not closing, you should have the system checked by a qualified technician.
Old 05-22-2009, 12:29 AM
You need to evac the a/c system to replace either low or high pressure on/off switch.
Thread Thread Starter Forum Replies Last Post
300TE Wagon Aux Fan Blows Fuse abeavens Mercedes E Class 3 03-08-2007 01:20 AM
05 C240 4M Aux Fan Relay/ Wiring Diagram Sassen Mercedes C Class 2 03-02-2006 12:46 PM
Aux cooling fan dead.. Xacting Mercedes E Class 1 07-22-2005 08:57 PM
Cooling fan (AUX Fan) sensor, ML-320 haidarsaid Mercedes M Class 1 01-22-2005 11:51 PM
Aux. Fan on a 260E 1989260E Mercedes E Class 5 01-28-2004 09:24 PM
Tags
ac, aux, benz, control, current, e320, fan, mercedes, pressure, receiver, replace, switch, switches, test, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
