83 300SD Electrical problem
My 300 SD keeps blowing the fuse for the blower motor/AC only when I run the fan on high. Common sense would say that the blower motor is drawing too many amps. I switched the motor with to one from my 85 SD...same. Then I swaped the blower control, ECU, and puch button switch, same thing.
I can put my finger on the fuse a feel it heat up after I switch the blower to high. AC or heat is no difference.
Has anyone experienced this problem???? I'm perplexed.
khwaja
03-18-2009 05:34 PM
