Detailing Discuss detailing your ride inside and out here.
Removing sun visor stickers
Old 02-11-2007, 07:13 PM
Barry Hanna's Avatar
Default Removing sun visor stickers
Just gently heat them and pull off? Can I use the 3M solvent for any residual stickum?
Old 09-11-2010, 08:54 AM
ripa's Avatar
I had the same question. Did you get them off?
Old 09-30-2010, 09:22 PM
ncmudbug's Avatar
I recently took off the ones that show (I didn't take the ones that don't show when the visor is up) from my 2005 C230K. They just peeled off. I didn't anything special except try to be careful so I didn't end up with half a sticker on my visor!
YMMV
Jim
Old 06-18-2014, 08:26 PM
mercful's Avatar
Wd40 can remove it and use a plastic scraper and blade to scrape it off.
Old 01-30-2018, 04:58 PM
RSAUTOSPA's Avatar
you can use googone to remove the sticky glue.
Old 03-03-2019, 01:51 PM
I used to work in a sign shop and had to eliminate this stuff daily and used a heat gun to soften the glue and then scrape it off with an old credit card. Any one of you can use a single edged blade to scrape on the glass. We tried not to use solvents on them, it causes more troubles than it helped.
brookings
03-20-2015 02:21 AM
Charlie C
08-25-2010 12:39 PM
ras716
07-12-2008 07:17 AM
tancalvo
08-08-2006 04:33 AM
aharley1
07-28-2006 10:37 PM
Quick Reply: Removing sun visor stickers
