cigarette lighter wiring question
I am hooking up an aux iphone cable so that it will charge as well as play my tunes. I want to hook the power supply to the wires going to the cigarette lighter, but there are four wires. Anyone know which colors are ground and power?
Pos & Neg at cig lighter
Use Volt meter cheap at Radio shack read ground first w/meter on ohms if it shows resistance that is ground turn key on read other wires with black probe on the body metal ( the ground ) and meter on volts when you find 12 volts you have your 12 v feed and use the body ground
good luck
good luck
albfamily
05-09-2005 06:00 PM
albfamily
05-06-2005 06:00 PM
